Network Management
Contributor II
AirWave report or APs/Devices List options for Wired Interfaces Speed
Hi all,
I'm looking to extract from AirWave a list of all my APs that are connected to a 100Mb switch port instead of a 1Gb port. I don't see any colunm in the APs/Devices List and I also tried to do a custom report but I find nowhere an option for that.
The thing is AirWave know about this info because if I go to a individual AP/Device, there is a Wired Interfaces section. In there I can see the Duplex, Input Capacity and Output Capacity. I would like to be able to sort by these field so I can request a cross-connect upgrade to four pair in the LAN room where they are connected.
Re: AirWave report or APs/Devices List options for Wired Interfaces Speed
Please see the post here:  http://community.arubanetworks.com/t5/Wireless-Water-Cooler/Report-of-all-WAPs-connected-at-100-Mbp/m-p/206049/highlight/true#M514
Contributor II
Wow! Ok.
Thanks for the link but not really user friendly... Doesn't make sense to have to do it this way. We should be able to do it from the GUI.
Does it need to be a feature request?
Yes.
Thank you.
Honestly, all you will have to do is SSH into Airwave and copy and paste in the two sections of text below:  Just replace your email address with userid@somecompany.com and it will email it to you:
dbcsv "SELECT ap.name,interface.if_speed_in/1000000 AS connection_speed FROM ap INNER JOIN interface ON ap.id=ap_id WHERE interface.oper_status=1 AND (ap.type=296 OR ap.type=369 OR ap.type=464) ORDER BY connection_speed,ap.name" > ./intspeeds.csv
echo "Access Point Port Speeds" | mail -s "Port Speeds" -a intspeeds.csv userid@somecompany.com
rm ./intspeeds.csv
 hats off to rwilsonblue for coming up with this.
Super Contributor I
Really good stuff and works like a charm!
Anyone with enough skills to add a column for duplex to this?
Christoffer Jacobsson | Aranya AB
Aruba: ACMX #537 ACCP | CWNP: CWNA CWDP CWSP CWAP
