Network Management
Occasional Contributor I
AirWave sizing
New Aruba customer here looking to deploy AirWave on vSphere 6.5..  WIll be managing about 250 APs and 75 switches in a campus environment.  Is there a best practice/receommendations for sizing HDD, RAM, vCPU?
Re: AirWave sizing
Hi ,
Follow below link
https://community.arubanetworks.com/t5/Aruba-Solution-Exchange/AirWave-Server-Sizing-Calculator/ta-p/285961
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
Re: AirWave sizing
Thank you Pavan.  What is the latest version and where can I find the iso or OVA?
Re: AirWave sizing
8.2.6 is latest available version. We can download from support site but need aruba credentials to access the site.
https://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/EntryId/28925/Default.aspx
Pavan
Pavan
Re: AirWave sizing
Thank you. I'm a new customer, how do I go about adding my service conract, which seems to be required in order to download anything.
Re: AirWave sizing
contact support
http://www.arubanetworks.com/support-services/contact-support/
Pavan
