Hello
Before i open a Aruba TAC case, i wanted to see if anybody had a solution for us.
A customer of mine with several controllers and about 300 AP's are now migrated to 6.3.
They haven't upgraded their AirWave accordingly, not that you need it, but they have used it with success so far.
They have added buildings and floors, and have spent far amount of time on it.
When they now try to upgrade, it fails.
First round they tried to upgrade to 7.7.x, and it failed, breaking the AirWave application. Backup at hand, they reinstalled 7.4.8, loaded the backup, upgraded to 7.4.9 and tried again, upgrading only to 7.5.2, and again it fails.
I include the simple log for the last fail:
[root@airwave mercury]# start_amp_upgrade -v 7.5.2
Directory not specified; using /root.
Upgrade script AMP-7.5.2-amp_upgrade was not found in local cache.
Upgrade package AMP-7.5.2-x86_64-cvs.tar.gz was not found in local cache.
Preparing to connect to Aruba Support Center...
Enter your Aruba Support Center username: jarle.teigen@hit.no
######################################################################## 100,0%
Checking for any patches or modifications to the code
This process may take a few minutes...
No outstanding changes were found. Continuing with the upgrade.
Validating the upgrade package...
Upgrade package is OK.
Upgrading AMP to version 7.5.2 from version 7.4.9...
Detailed log will be written to /var/log/upgrade/AMP-7.5.2-upgrade.log
STEP 1: Moving old version aside.
STEP 2: Unpacking upgrade package.
STEP 3: Checking for compatibility.
STEP 4: Stopping AMP services.
STEP 5: Installing upgrade.
make: Leaving directory `/root/svn/mercury'
regulatory domain took 0.20s
firmware version stuff took 0.88s
(update_db.pl ready_all/wait_all took 7.77s)
Completed update_db at Fri Aug 30 13:55:49 2013
(cd /usr/local/airwave/lib/java; JAVA_HOME=/usr/java/jre /bin/su visualrf ./visualrf_schema.sh)
./visualrf_schema.sh: line 2: /usr/java/jre/bin/java: Ingen slik fil eller filkatalog
make[1]: *** [updatedb] Error 127
make[1]: Leaving directory `/root/svn/mercury'
make: *** [upgrade] Error 2
Upgrade aborted.
Please contact Aruba Networks Support at
1-800-WiFi-LAN or support@arubanetworks.com
DISABLED - 2!!
They are running an appliance, no VmWare involved.
Looks like the installer moves the files, but as the upgrade fails, it is unable to cleanup, breaking the AirWave application.
Anybody having an idea what causes this, and how to fix it?
The appliance do have lots of free disk space.
Roar Fossen
