Network Management
Airware Web Very Slow
Recently use Airware  Web  Very Slow
the memory using very hight ,but use top command  process max only use 2x&
Regular Contributor II
Re: Airware Web Very Slow
Hi
Did you size the server with the sizing tool for AirWave?
Did you install more devices into airwave recently?
Hope it helps
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
Now i have 62 Device
The VM Size : 1 Core 2 thread /with 5GB Ram
Moderator
That's even smaller than the VMs I run in the lab!  Our minimum setup in the lab is the same as the minimum for the OVA image that we provide, which is 4 core, 8 GB RAM, 60 GB disk (if VM, thin provision, and make use of snapshots).  We don't perform any performance tests against smaller setups.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Hi
Stick to the specs of the 1500 devices airwave even if it is a smaller deployment.
Cheers, Frank
Contributor II
RE: Airware Web Very Slow
Moderator
That link is to an older spec from 4 years ago.  The product has changed, there's new features that require more processing capabilities.  While you could follow the old sizing guide, it doesn't help much since it doesn't take into consideration the newer features like Traffic Analysis, Clarity Live, updated VisualRF algorithms, etc.
Rob Gin
Hi
As the ASE airwave sizing calculator isn’t available anymore I would stick to the 1500 version from the 8.2.6 server sizing guide.
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=29748
Cheers, Frank
