Network Management
Contributor I
Airwave 7.4.8 - Ignore Decommissioned AP's
Hi, previously I was able to ignore AP's when I decommissioned them and have them sit there in the event we would redeploy it without having it count against my licensing.  Is there a way to do this now without deleting them along with the old stats.  Once they are rediscovered and new I have the ignore button option.
Thanks!
Aruba
Re: Airwave 7.4.8 - Ignore Decommissioned AP's
Today, you can do that by creating a Maintenance Window for those APs.  For one AP at a time, you can do it on its Manage page.  If you want to add multiple devices to the same Maintenance window, you can do that with the Modify Devices feature on any list of devices.
Contributor I
Thanks Dan, that worked.
