Network Management
Super Contributor I
Airwave 7.5.6 and AirOS 6.3.1.2
Anyone having issue getting AP225 in bridge mode to be shown on the Airwave server running7.5.6?
Normal Guy
Re: Airwave 7.5.6 and AirOS 6.3.1.2
The 225AP and AOS 6.3 is supported on 7.7.x
Thank you
Victor Fabian
Lead Mobility Architect
Super Contributor I
Thanks Victor.
Normal Guy
Super Contributor I
Anyway found the AP it is showing as AP50. :smileymad:
Normal Guy
Yeah I seen that before it just not getting recognize properly
Thank you
Victor Fabian
Super Contributor I
Thanks Victor, wil be upgrading the Airwave.
Normal Guy
