Network Management
Airwave 7.7.10 and IE9
I feel silly asking -- given how old IE9 is, but it was working yesterday, and now it's not.
I upgraded from 7.7.9 to 7.7.10 and today users get either a blank white page, or a blank white page with the "helpful" missive "error on page" in the status bar.
I didn't see support for IE9 ending listed in the release notes, so I'm hoping this wasn't intended.
Anyone have a fix or workaround?
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
Re: Airwave 7.7.10 and IE9
Unfortunately I don’t  have any solution.  I could just say that you are not alone,  I have the same issue after a upgrade from 7.7.7 to 7.7.10.
In the release notes we can find some issues with IE9 with VisualRF but it all.
