Network Management
Regular Contributor I
Airwave 7.7.11 is there a way to view most used APs by time?
I am wondering if there is a way to track which APs have the most clients on them at certain times of the day. As a member of IT I get to hear fun phrases like "It happens for everyone at like 2pm every day" which generally means 1 or 2 people are affected, but I'd like to do my dillegence trying to diagnose potential issues in the network.
I think by being able to see where the majority of people are connected at certain times of the day may help me find some possible load balanced issues.
So, is there a way to view which AP's have the most clients associated at a specific time? (I know I can look at each individual AP to see how many clients are connected)
Trusted Contributor I
Re: Airwave 7.7.11 is there a way to view most used APs by time?
You could configure a Device Summary report and use the "Most by Maximum Concurrent Clients".  This will rank top utilized APs and display the following for each AP:
  • Client count
  • Max clients
  • Total data
  • Avg usage
The data displayed is for the time frame you specified using the Report Start and Report End parameters.
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Perfect. Not necessarily by the hour, but at least gives me some insight on which APs are being used the most. Thanks!
Yeah, that's unfortunately the only way I'm aware.
You could create many of these reports and change the start and end time for each business hour of the day. This would give you what you want, but split up amongst many reports. Not ideal, but that may be the closest thing to what you're looking for.
Do you happen to know. Is there a way to tell what time of the day the max clients on that AP were reached?
For example I have a few APs that I show having a max count of 36 clients. I'd be interested in knowing what time of the day that happened.
Short of setting up the hourly report like we had talked about, do you know a way to decide?
Unfortunately, I do not know how to do that short of setting up the hourly report.  Sorry, but maybe someone else has a thought?
