Network Management
Occasional Contributor I
Airwave 7.7.12 is reporting negative values on graph
Hi Community,
I found that when using the "Reports" tab the AirWave server would draw a negative graph for "Usage", which is quite awkward.
Why does that happen? Is there anything I have to do differently?
Benny
Twitter: BennyE_HH
My Homepage: http://dokuwiki.alu4u.com
Moderator
Re: Airwave 7.7.12 is reporting negative values on graph
It's just a negative axis on the graph to help visualize the differentiation in direction of traffic from a device (out/in = request/response).  Note how the summary shows only positive values.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
