Network Management
MVP
Airwave 7.7.5 and AOS 6.3.1.0 - mismatch (more like no-match)
I upgraded both AMP and AOS in the same week, so I don't really know if it's a 6.3.1.0 bug or a 7.7.5 bug (or just a problem with my installation)
At this time AMP shows all of my 3400/3600 controllers as mismatched. Specifically all configuration lines added in the upgrade or changed since the upgrade turn up in the Audit page as mismatched.
Clicking Import on the Audit page makes a lot of syslog entries, and percolates for a while, but none of the proposed changes occur, and the audit page remains resolutely unchanged. Same for Import from the Management page.
(note the controllers are monitor-only devices, I plan to manage them AFTER I get all of the mismatched resolved)
Any one else see this sort of issue, or running the same versions and working fine?
(I am on the wasy to TAC, just checking with the community on route)
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
Aruba
Re: Airwave 7.7.5 and AOS 6.3.1.0 - mismatch (more like no-match)
This is a bug -
PLEASE UPGRADE to 7.7.6 which was released yesterday
From ssh@root prompt
# start_amp_upgrade -v 7.7.6
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
MVP
Thanks for the quick response.  I'll let TAC know you said so ;)
I'll also upgrade tonight -- I'd already downloaded the patch, but was going to wait for TAC to finish collecting whatever data they wanted.
--Matthew
MVP
That fixed it.
I'll let TAC know...
--Matthew
Aruba
Sweet!
Seth R. Fiermonti
Sr. Systems Engineer
ACMP, ACCP, ACDX, ACMX
Seth R. Fiermonti
Email: seth@hpe.com
