Network Management
Airwave 7.7.7 - Unknown role in Session Data by Role (Clients by role)
[ Edited ]
Hi All,
I have a query, on Airwave running 7.7.7, the "client by role" it shows lot of clients on unknown role. However there was no role named "unknown" on any of the controller. Could anyone let us know what the "unknow role" refers here.
Moderator
Re: Airwave 7.7.7 - Unknown role in Session Data by Role (Clients by role)
The role 'unknown' is a catch for all client entries where AMP doesn't receive role data information.
What type of controllers are being monitored?  If Aruba, what method of client data collection is being used (SNMP or AMON)?  Often times SNMP polling was reduced to lighten load on the controller, which means that traps were relied on, but traps do not contain the role information data.  Is this a DMZ setup?  If DMZ, is the internal authenticating controller also monitored by AMP?  For DMZ setups, we've seen that if you add the external facing controller without the internal authenticating controller, then we only get half of the client auth information.
A next step would be to open a support case to have support collect a data capture and parse that capture to see if AMP is getting the role information in the packets.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Thank you for your suggestion. i will open a support case.
