Network Management
Airwave 7.7.8 VisualRF issue
We spun up our Airwave server and it imported all of our controllers and APs.  I began placing the APs on maps of our buildings in VIsualRF but ran into an issue with a few APs.
Most of our APs show their heatmap after being placed, but some are not.  When I click on the AP and then click the antenna for info it says Status:Error.  I know the ap is functioning because it has clients associated to it.
I tried removing from the map and readding but it still shows Error.
Any ideas?
Mo
Contributor I
Re: Airwave 7.7.8 VisualRF issue
I had the same problem here. Solved using 7.7.9.
Mo
Moderator
The /var/log/visualrf/visualrf.log may show a more verbose reason for the error.  Which AP type are you working with?
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
I am seeing it on 93H's and 135's
Respectfully,
Josh Bauman
Network Infrastructure and Security Administrator
Maryville University St Louis
314-529-9512
[jbqrcode]
Moderator
Interesting, and was there anything additional in the visualrf.log?  Possibly radios assigned to a txpower setting that's not in the library or something similar?
Rob Gin
I will have to look. I will post what I find.
Respectfully,
Josh Bauman
314-529-9512
[jbqrcode]
Hi Mo;
Same problem in 8.0.9.
2016-01-07 17:11:01,148 ERROR Grid Bui[2]  com.airwave.rf.SignalService Device ALS-TBP-Tapete37 radio[1] is invalid, skipping.
Moderator
For those running into this, please be sure to open a support case.  It would definitely help since we're not seeing this issue often in our lab, and it appears to manifest differently for different customers.
Rob Gin
Thanks.
We will be opening a case for this issue seen in 8.2.2
