Network Management
Airwave 8.0.0 and IAP-105 getting apprf data
We just updated our Airwave to version 8.0.0 and are trying to figure out how to get the appRF data from our IAP-105 access points to poplulate in Airwave?  Is there a trick to this or is it possible without using a controller?  I upgraded the firmware on the access points and can see the appRF data in the Access Point but its not populating the appRF area in the 8.0.0 Airwave.
Re: Airwave 8.0.0 and IAP-105 getting apprf data
AppRF in Airwave and IAPs are not supported in the 8.0.0 release.  This is only applicable to controller based networks with regards to AppRF data in Airwave
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Is this slated to work in a future release?
you got AppRF to work on an IAP-105? the 105 shouldn't support AppRF with 4.1.
as far as airwave and APS that support AppRF I'm sure that will come at some point.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
