Network Management
Contributor I
Airwave 8.0.7.1 Controller Backups
Not sure when Airwave got the ability to start doing controller backups but looks like it can. Is there a way to make all contollers backup at a specific time? I know you can manually do backups under "audit" tab under a device but I can't seem to find any place you can schedule tasks for backups
Valued Contributor II
Re: Airwave 8.0.7.1 Controller Backups
HI,
No you can not schedule but if you enable it can backup the configuration 2 daily backups (Nigh time), one Weekly backup and one Monthly back up. on this we do not have any control.
you have another option also, if we select archive option in the group settings, it will pull and archive the controller config whenever there is a change in the config.
Please feel free for any further help on this.
Cheers,
Venu Puduchery,
Contributor I
Where do you enable backups daily, weekly, and monthly?
Here is the description and procedure for Controller backup and restore.
Cheers,
Venu Puduchery,
