Network Management
Airwave 8.0.9.1 VisualRF - cannot move campus? like drag and drop it somewhere else...
For whatever reason, I cannot drag my campus to another location on the map.
Not matter which browser I use....
I select it and try to drag it nothing....
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Re: Airwave 8.0.9.1 VisualRF - cannot move campus? like drag and drop it somewhere else...
Did you unlock at the top?
Tim Cappalli | Aruba Security
Are you kidding me....
It's the holidays, I am blaming it on that.
ACDX #420 | ACCA
Step away from the eggnog.
Ya but it's soooo good ;)
Thanks Tim for the help. I was going insane
ACDX #420 | ACCA
