Network Management
Contributor I
Airwave VisualRF
When we bring up a map in VisualRF and click on clients they are all positioned in the upper left corner of the map. Anyone know how to get them to go where they belong?
Re: Airwave VisualRF
We have a had a few support cases for similar behavior.  Please open a case with TAC so that we can help assess if it's the same issue that is already being investigated, or so that we can help raise new defects if it's same symptom but different cause.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
