Network Management
Trusted Contributor I
Airwave 8.0 Beta Upgrade
Couple of questions regarding the Airwave 8.0 Beta release:
  1. Will Airwave 8.0 report call history if I am currently using the Lync APIs (not 2.0) and AOS6.3?  I asked at the conference, but couldn't get a concrete answer if AOS6.4 is required for Airwave 8 to report call quality.
  2. Is the offline upgrade still the same for betas?  Drop the upgrade file in root and run start_amp_upgrade?
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Moderator
Re: Airwave 8.0 Beta Upgrade
1) UCC dashboard requires minimum of AOS 6.4.  Here's a capture from 8.0 BETA AMP Setup tab:
2) The offline upgrade is still the same process.  Beta announcements will be sent out by the product management group once an official Beta build is ready.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Well, I suppose I'll hold off then since I'm not ready to upgrade to 6.4.
Is the 8.0 release in the beta folder on support not considered an "official beta build"?
Thanks Rob.
Moderator
The Beta currently in the beta folder was supposed to be an internal only build, no customer facing build has been made yet.  If you're seeing it, then the permissions on the support site probably need to be revisited.  That or you paid off the right support site admins.
Rob Gin
Haha!  Thanks for the info, Rob.
