Network Management
Airwave 8.2.4 all aps mismatched
I have recently upgraded to Airwave 8.2.4 and all went well and moved the access points to 6.5.2 which is supported from what i read in the release notes, however once i did that i have 1100 aps all working but they are in the mismatched state.  If you check them there is no mismatches that i can see other that a few waiting to be renamed.  I downloaded and uploaded the firmware for all of our types (205,215,305,315)
Is there some way to make them all match again?
Moderator
Re: Airwave 8.2.4 all aps mismatched
Are the APs off a controller or Instant APs?
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Hey Rob,
They are 1 virtual control per site with anywere from 6 to 60 instant ap's clustered and all managed by airwave.
Moderator
Got it, and are you using templates for config or the Instant GUI Config?
Easy way to tell is when you go into the group, you either see a templates tab or an Instant Config tab as one of the group breakout tabs on the left menu.
Rob Gin
Hey Rob,
I am using instant config!
Thanks!
