Network Management
Airwave API to Retrieve Reports or Send Reports with ftp or scp
Is there a way to use the Airwave XML API to retrieve reports?  We'd like to use a cron job to download and save reports from the Airwave.  I've seen sample code for a few things but nothing related to reports.  Is there an API reference? Or as an alternative, is there a way to deliver reports using ftp or scp instead of email?
Thanks!
Contributor II
Re: Airwave API to Retrieve Reports or Send Reports with ftp or scp
Anyone knows something abouts this? API and reports possibilities?
Moderator
The APIs will not access this feature, it'd be an RFE to add this ability to the APIs.
What version of AirWave are you running?  If you're running AMP 8.0 or newer, there should be options in the report definition:
It allows you to directly export reports over FTP or SCP in both CSV and PDF formats.  Make sure the path is a valid path.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
