Network Management
Occasional Contributor I
Airwave Alerts
Hello, I was wondering if there is a way to setup Airwave to check to see if Radius is authenticating wireless users and if it is not to send an email or some type of alert telling me so?
Re: Airwave Alerts
You bet.
1. Make sure you have enabled SNMP traps on your controller to be sent to Airwave.
2. Create an AMP trigger using the Radius Authentication issues Type
Choose either Client or Device, you can select a count (how many times you want it to occur before being triggered).
As a side, you can also have a report created and emailed to you daily.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Contributor I
Re: Airwave Alerts
Hi Guys
Can Alerts  be triggered to Airwave management once a user gets close to reaching their limit.
Maybe a Radius attribute sent to Airwave?
How can we do this please?
Harry
Re: Airwave Alerts
mahathma wrote:
Hi Guys
Harry
Close to reaching what specific limit mahathma?
Contributor I
Re: Airwave Alerts
Hi Colin
When a user reached their allocated quota of say 1GB, I know radius can send COA attribute and Instant AP can change role.
Can an alert be sent to Airwave by radius once this limit is reached?
Re: Airwave Alerts
A separate system must be in place besides airwave to monitor the bandwidth, send a COA and send Airwave a trap or syslog message.  Airwave can then look for that syslog or trap.
Contributor I
Re: Airwave Alerts
Thanks Colin
Re: Airwave Alerts
Dear Friends,
I also have similar question but little different is that
I want to get alerted when any device down from airwave .
I configured as follows
system>triggers>add .  then filled all the required fields.  there was alert setting lowest time was 5 minutes.
For testing purpose, I removed Access Point from the network for 25-30 Minutes but I did not receive an email alert.
Please suggest me to get alerted.
Thank you so much in advance.
Regards
Ambaraya
Re: Airwave Alerts
Does the access point show as "Down" in Airwave?
Re: Airwave Alerts
Hello CJ,r
thank you for your reply. Yes it was showing down in airwave.
