Network Management
Super Contributor II
Airwave, Clarity and now Glass ..... how do they fit together
While browsing the downloads section of support.arubanetworks.com I noticed another ova file has apeared under the Airwave folder. Having  built a clarity engine and linked it into our airwave server, what does glass do ? A glance at the PDF seems to say it's a front end for multiple Airwave servers. If youve got 1 server, any point in Glass ? Given Airwaves limited SNMP support for non Aruba kit, does Glass manage other vendors?
Rgds
Alex
Re: Airwave, Clarity and now Glass ..... how do they fit together
Glass is a “next-gen” master console designed from grounds up using cloud computing technologies with a lot of new capabilities compared to its predecessor! Glass 1.0 offers the following
1. High performance and scalable platform
a. Scales to 30,000 network devices and 300,000 client devices for Aruba WLAN (AMON only)
b. Scales to 50,000 network devices and 500,000 client devices for 3rd party WLAN (SNMP only)
2. Next gen aggregate dashboards
a. Snapshot and time trend views
b. Overview, RF health, AppRF, UCC, Clarity & Client Session dashboards
3. New framework for aggregate reporting
a. Summarized “executive” reports with the ability to customize with logos etc.
4. Built-in Single Sign On (SSO) for easy navigation between AMPs and Glass
5. Advanced Search
a. Search for Network Devices, Clients, Folders, Floors, Rogues
b. Partial search, prefix search depending on search parameters
c. Granular filters
6. Aggregate views for VisualRF and RAPIDs
7. RBAC for administrative access
8. Cloud based modular image upgrade process
Glass is next generation of master console, which manages mutliple primary servers which manages/montior mulit vendor products.
Pavan
If my post address your query give kudos:)
Pavan
If my post address your queries, give kudos and accept as solution!
We have few challanges in using master console, to overcome those challanges Aruba introuced Glass 1.0
Pavan
Pavan
Where can we get support for Glass? I'm trying to deploy and it doesn't seem to be communicating with the first AirWave server I tried to link it to? I get "Waiting to hear" for the "Last Heard" value. It doesn't appear I can do anything else within Glass at the moment.
Hi ,
As per my knowledge support started from April 10th 2017, but I am not exactly sure, please check with your Aruba sales team for more details.
Have you installed Glass on physical machine or Virtual ? Currently Glass is supported only on VMware.
Pavan
If my post address your query, give kudos:)
Pavan
Frequent Contributor I
Any benefit from running Glass with a single instance of AirWave?
There is no benfit if you have only one managed AMPs, since all the clarity, AppRF, reporting information will get from the same server. Airwave Glass is used in mulitple managed AMP scenario.
Pavan
Pavan
There is a requirement that AMP needs to be running on 8.2.3.1 for Glass to work. What version of AMP do you have running?
We need to be on AMP 8.2.3.1 and need to add with FQDN managed AMP not IP in Glass.
Pavan
Pavan
Hi Pavan,
We're on 8.2.3.1, and did use a FQDN. Interestingly, Glass never seemed to get fully connected, but it did insert its hostname in Airwave under the CAS field, which then popped into the URL at logout.
