Network Management
Airwave Clients and Usage dashboard widget view only
Can a user be restricted to just the dashboard Client and Usage widget (set a particular folder)?  Or can those real-time graphs be exported to another server somehow?
I'd like to provide the real-time graphs to another party, but that party cannot have access to the other capabilities of AMP.
Re: Airwave Clients and Usage dashboard widget view only
Try the settings below:  Unfortunately, users will be able to access other screens outside of what they can access by directly using the URL:
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Moderator
You might be able to leverage the APIs to create your own graphs.  Otherwise another way to do this might be to run reports and have the report emailed to the party that needs the data.
Beyond that, it sounds like it'd make a great feature request if we can get further understanding of how they are using the data.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
