Network Management
Airwave Controller Error Mismatch
in Airwave I'm getting the following error
then when i click on it i get this message
i have no firewall between Airwave and this controller, i have checked the password and the community and there are true.
i have also other controllers , that work fine with the same configuration
I can't find the cause of this issue any help
Regards
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Contributor II
Re: Airwave Controller Error Mismatch
Had that problem earlier today. In my case it was a firewall policy blocking SSH towards controllers. Hope it helps.
Alan
Kind regards,
AlanFord
Contributor II
Sorry, just saw FW comment :-(
Kind regards,
AlanFord
Contributor II
Hi Raouf,
Just a quick one. Had a chat with TAC guys, and issues in my case was that SSH executed commands were not having enough time to run due to lag on LAN. Fix was to extend time allowed to 30sec (under Device Setup -> Communication). Hope it will help you as well.
Telnet/SSH Settings
Telnet/SSH Timeout (3-120 sec):
Alan
Kind regards,
AlanFord
thank you flolks,
Alan , your proposition solved the problem
Regards
Raouf CHAHBOUNE
