Network Management
Airwave - Customize VisualRF Heatmap Signal Cutoff
  • 1.  Airwave - Customize VisualRF Heatmap Signal Cutoff
    Posted Jul 25, 2018 03:18 AM
    Hi.
    One of our customers wants to use the "AP Overlays" Heatmap of Airwave VisualRF and change the "Signal Cutoff" to "-60 dBm".
    There is a drop-down menu where i can only choose beetween "-45, -55, -65, -75, -85 and -95 dBm".
    Change to another value has no effect.
    Is there a way to modify this to have a cutoff at -60dBm?
    Regards, Marco
  • 2.  RE: Airwave - Customize VisualRF Heatmap Signal Cutoff
    Posted Jul 25, 2018 06:08 AM
    We can not edit singal cutoff value to 60, so changing cutoff value not reflecting any change in heatmaps?
    If yes then you need to look in to floor size, if gridsize is large then changing cutoff value does not help, try resize the floor and check the status.
  • 3.  RE: Airwave - Customize VisualRF Heatmap Signal Cutoff
    Posted Jul 25, 2018 07:41 AM
    Hi.
    Oh no, i expressed myself wrong ;)
    Changing the cutoff reflecting changes in heatmaps.
    From -0 till -54 go to -> -45dBm (red)
    From -55 till -64 go to -> -55dBm (orange)
    From -65 till -74 go to -> -65dBm (green)
    etc.
    So, it is not possible to set the cutoff value individual? OK.
