Network Management
Airwave Device Summary Report Issue
I have two SSIDs that are on my WLAN network and would like monthly device reports for each SSID.  The problem I'm having is when create a report for each SSID the data is same on each report.  SSID 1 looks like SSID 2.  Am I doing something wrong when creating the report or is this an issue with Airwave?
Moderator
Re: Airwave Device Summary Report Issue
Good catch, this has been filed as DE14016.  The client and max client count seem to cover the total client counts of those APs during that time frame, but they should be showing only clients and max clients for clients associated to the filtered SSID.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Has this issue been fixed?  If not do you know when it maybe.
Moderator
This has been fixed in AirWave 7.7 code.  AirWave 7.7 is expected for release within the next 2 weeks unless any critical bugs are found.
Rob Gin
Has the Airwave Device Summary report issue been fixed?
Moderator
Yep, this was fixed in the initial 7.7.0 release.  If you're planning to upgrade, you should plan to upgrade to the latest release: 7.7.4.
Rob Gin
