Network Management
Regular Contributor I
Airwave Failover Alerts
I was wondering if anyone knows of a way to have the backup AMP send an alert to NMS or email when it is promoted.
For example if we have an AMP01 and watcher AMP02. If AMP01 goes down and AMP02 promotes itself we would like to receive some sort of notification.
Is this possible through the built in Triggers system, part of the Watcher config, or perhaps if we enabled the OS level SNMPd?
How is everyone else monitoring for AMP failure events?
_ELiasz
ACDX, ACCP, CISSP, CWNA
Re: Airwave Failover Alerts
it is possible. you can create a trigger for amp down
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Thanks, i see that i can create a trigger on the Watcher to alert. I asked some people and they said it wasnt an option. i should have looked for myself.
Thanks again
