Network Management
Contributor I
[Airwave] How to customize system name
Dear all friends and experts.,
I want rename of Airwave system name . Current name is " AirWave Management Platform 8.2.2".
I want to rename it to something. I know that is cuztomize OS. but i dont know how ?
Please help me on case im facing. Thank you so much!
Regards!
Re: [Airwave] How to customize system name
Airwave-01 below that is your system name.  Airwave Management Platform 8.2.2 is showing you the version of Airwave and is NOT the system name.
Contributor I
Thank you friends. I know what you told me.
But  I want rename " Airwave Management Platform 8.2.2 is showing you the version of Airwave" to something, is that possible ?
Thank you so much !
I don't think that is possible, no.
Moderator
The product header is hardcoded.  It only changes if you're on a rebranded OEM version of AirWave.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
