Network Management
Airwave IAPs Client Blacklisting
Hi All,
I'm currently deploying a customer's AMP-8.0.9.2, with IAPs on v6.4.2.6-4.1.1.10_51810.
We're also using the Instant-GUI-Config in the groups.
Within the Instant GUI config, I can see the manual blacklist options which is fine.
Within the client details I can see the deauth button which is fine.
I can't find an option anywhere to dynamically blacklist a client?
I assume it's not possible???
Kudos appreciated, but I'm not hunting! (ACMX 104)
MVP
Re: Airwave IAPs Client Blacklisting
What kind of dynamically blacklisting do you need?
Some types of blacklisting you have in the Instant:
* add a rule on the role which triggers a client blacklist - for x hours
* Dynamic blacklist on auth failure for x hours
You can find triggers for dynamic blacklisting under Security -> Blacklist
Regards
John Solberg
-ACMX #316 :: ACCP :: ACSA
Aruba Partner Ambassador
Intelecom Group - Norway
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
You know what, I phrased my question really badly.
What I was trying to work out, was whether from within Airwave (which is managing IAPs) you could MANUALLY blacklist a client "on the fly". Like with a controller GUI, where you'd just select the client and hit the "blacklist" button.
I found this old post in Airheads...
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/How-to-kick-a-user-off-WLAN-fro-Airwave-on-a-managed-iAP/td-p/111697
However, I've tried the "contain" option mentioned in that post, and it doesn't have any affect on the client. I.e. the client just re-auths.
Why wouldn't you navigate to Security -> Blacklisting
Then add an entry there to manually blacklist.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACMP
[If you found my post helpful, please give kudos!]
You/we could.
It's just not very "slick" is it? Compared to a one-push button.
