Network Management
Airwave IGC and Instant Wired Ethernet Port profiles
Does anybody know if Airwave  IGC can configure ethernet port profiles?
I can't seem to find the hook for it in 8.2.
i can define the custom profile but can't assign an ethernet port to it.
Would the default profile be the best place to make a change with overrides for a site with a different condfiguration??
