Hi Guys,
I am trying to install Airwave, but the following errors appears.
Does anyone knows how to fix this problem?
Thank you in advance.
I suggest opening a support case. My first look would be to check for any additional error details from /root/amp-install.log. Was this installation completely done using the AirWave installation ISO?
