Network Management
Contributor I
Airwave Installation problem
I am new to airwave. I downloaded AMP-7.2.5.iso file from support.arubanetworks.com I have 32bit PC and that file is also of 32bit. When trying to install Airwave in VMware Workstation I experienced the problem that is attached as attachment.
After that I downloaded CENTOS file name CentOS-5.1 DVD.iso it installed successfully but know again I am unable to install Airwave please tell me that how can I Install airwave I followed Airwave User guide but unsuccessful. Please help me.
faisal
Aruba
Re: Airwave Installation problem
The AMP iso will also install the OS.  No need to install Centos first.  Just boot off the AMP iso.
:smileyhappy:
ACCP, ACMP, ACMX #294
mclarke@arubanetworks.com
Contributor I
I tried but having a problem AMP ISO could not start due to some errors. the snapshot of error  is attached for your kind information
[ Edited ]
The only issue I have run into installing it on a desktop in VMWare is that the disk needs to be a virtual SCSI disk (not IDE). Make sure you setup your disk that way before installing.
Zach Jennings
Contributor I
I made 2 VMs, 1 has SCSI and another has IDE Harddisk. But problem remain same.  Problem snapshot is attached please see attachment.           I might be possible that there is problem in AMP iso, i am downloading again .
Faisal
Contributor I
Problem remains same.
Please help
Contributor I
I downloaded again AMP iso but unsuccessful
Contributor I
Hi, I am installing Aairwave in CentOS but got a problem. I have 32bit OS and downloading the amp+linux OS from support.arubanetworks.com and version of amp is AMP 7.2.5.ISO 32bit distribution. When i used this ISO in virtual machine workstation as step by step mentioned in AMP User-guide I experienced an error whose snapshot is attached named as Error 1. Later that i download independent CENTOS ISO and installed it. It installed successfully now after that i downloaded the AMP package whose name is: AMP-7.2.5 .rpm and install it in CentOS by double clicking the package , after installing it I used terminal Box to Completely Install AMP-7.2.5 .rpm by using the following command " ./amp-install ", it started with no problem but during step 3 gave me an error whose screenshot is also attached named as Error 2 for your kind reference. Please help me that how can i resolve this problem. one more thing that when i goto my home directory/amp folder and double click on AMP-Install terminal windows appears but during step 3 window vanished and there is no sign of AMP installation i waited more thn 1 hour but there is no effect. Please Help me. Regards, Faisal
Contributor I
Please Help me.
Faisal
I'm curious why you wanted 7.2.5.  It's an older release and I'd recommend you try 7.4.8.  That will require that you run 64-bit.
If you try with the latest version of AMP and are still getting install errors, I'd recommend you contact TAC.
