Network Management
Frequent Contributor II
Airwave LIC Question
if i have AW LIC for 500 user & want to exnted to 700 user , so i need extension LIC for more 200 user :
Q1 :is it 200 * AW-EXP1-50  ... or is it : AW-200 ?
Q2 :Also for HW option  what is difference between "AW-HW-PRO : professinal "  & "AW-HW-ENT : enteprise "
Q3 :does HW needs LIC or it is included ?
Aruba
Re: Airwave LIC Question
First, the license is per managed device (AP, Controller, Switch, etc.)....not user.
  1. I've done it both both ways.  Either way, you have to consolidate the new license key with your eixsing one.   You chould be able to do this on the licensing.arubanetworks.com site; under My AirWave
  2. The difference is in the HW components; thus the supported number of devices;aw-hw-size.jpg
  3. the HW does not include the licenses
AMFX | ACCX | ACDX | ACMX
Moderator
Should keep in mind that if the server is older than 2 years, the expected values would be closer to
AW-Pro = 1000
AW-Ent = 2500
And if you have any problems consolidating your license key, support would be able to assist.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
