Network Management
Occasional Contributor I
Airwave Login Authentication with ACS 5.x?
I would like to secure our Airwave product by having our users authenticate against ACS instead of using the local database.  I've seen instructions for ACS integration before 5.x but nothing for 5.x and above.  The layout and options are a little different and the setup is not the same as what the instructions are.
Just wondering if anyone has any luck with it and can point me in the right direction?
Re: Airwave Login Authentication with ACS 5.x?
The ACS feature which made AirWave integration possible in the past was "custom attributes".  Cisco took that feature out in 5.0.  If it has been added back in, then it should be doable.
You can also use a RADIUS server for authentication of AirWave users.
