Network Management
Contributor II
Airwave Management WebUI security
My customer is using Airwave to deploy their Instant AP's, via Aruba Activate.
They want to put Airwave in the DMZ because they don't want to expose internal systems to the Internet.
They also want to make sure that the Admin WebUI is not accessible from outside their network - is this possible?
i.e. the IAPs will need to connect to the public IP address over https, so can we change the Admin port or IP to something else?
Re: Airwave Management WebUI security
You can do it but you would have to probably restrict the 443 access from only certain public IP address where your IAP will exist
IF  you already have TACACs in your environment you could tied Airwave to TACACs , and also remove delete the admin account
Thank you
Victor Fabian
Lead Mobility Architect @WEI
The IAPs "push" the info to Airwave.  Their port is 443 and cannot be changed.  I think a policy to only allow IAP traffic can be done but there would have to be a firewall/router involved prior to reaching Airwave
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Contributor II
Hm... that's no good.  They are deploying the IAPs with VPN, similar to RAPs.  So the IAP's will be scattered out all over the world, behind dynamic public IP addresses.  So they need to allow https from "any" to AMP's public IP.  But by default that will also allow "any" to log into the Management WebUI, which is not good from their perspective.
Contributor II
So no way to separate the Management WebUI traffic onto a different interface or port?
Yes...you can specify the management VLAN (Virtual Controller VLAN) in the Admin settings to separate it out.
Hang tight...I am researching what options you have.
Seth R. Fiermonti
Email: seth@hpe.com
Contributor II
Sorry, I think I'm missing something.  Where do I find the management VLAN (Virtual Controller VLAN) in the Admin settings?
Click on System ---> General Tab ---> Show advanced options
Make sure you're on the latest code as well.
Seth R. Fiermonti
Email: seth@hpe.com
Contributor II
There's no General tab under System in Airwave.
There is a General tab under AMP setup, but I don't see management VLAN anywhere in there.
I'm running AMP 7.7.1
Sorry...meant the IAP UI
Seth R. Fiermonti
Email: seth@hpe.com
