Network Management
Airwave Mass Group Creation
Anyway to use a script to create multiple AMP groups.
I need to create 28 AMP groups. I am doing this because I need to monitor the configuration of each controller as they are different.
Any possible way to do this using scripts? I got my answer in terms of Airwave folders.
Thanks.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Moderator
Re: Airwave Mass Group Creation
Yes, there's a create groups from csv script
# cd /root/svn/mercury/scripts
# ./create_groups_from_csv.pl
./create_groups_from_csv.pl <csv_data_file>
Create groups from a csv file. The first line will need to be group_name.
Each additional line should be the name of a new group. This version of the Group create script
is meant to copy a group that is very close to the default settings.
If there have been a lot of changes to the group you may need to comment out the two resub lines
for the groups to copy properly.
There is another script that will auto-authorize your APs and place them into groups for you.
That script will also create any groups that do not exist.
CSV Format:
group_name
Chem Building
Cafeteria
Library
Administartion Building
--> first row entry of CSV must be group_name
Here's an example run through:
[root@amp scripts]# cat /tmp/csv
group_name
group1
group2
group3
[root@amp scripts]# ./create_groups_from_csv.pl /tmp/csv
Created group1 group
Created group2 group
Created group3 group
Total Created: 3.
And then verify that your UI reflects the desired groups.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Thanks that worked just great.
What I liked about the script was that it copied the group settings I had already created (a modification of the default access point group).
ACDX #420 | ACCA
