Network Management
Frequent Contributor I
Airwave Mesh Graphing
Airwave shows us usage for regular AP's but when i go into a Mesh AP those graphs are empty.  Is there a way for airwave to graph the bandwith usage for a mesh AP?  i would really like to see the usage as this is a Point to Point mesh and it would be useful to keep an eye on the utilization of the link.   The AP's are AP 104 running AOS and airwave 7.5.4
Re: Airwave Mesh Graphing
We should be getting usage from the AP104s regardless if it's in mesh mode or not.  I'd suggest opening a support case and include a snmpwalk of .1 -Cc -On.
# s2w (controller ip) (community string) .1 -Cc -On > /tmp/s2w.txt
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
