Network Management
Contributor I
Airwave Performance Setting Adjusment
Server Spec:
CPU:E5-2640 v3 8C (90W) 2.6GHZ 20MB CACHE 1866 Mhz
Memory:60 GB DDR4
HD: 6TB 7.2K RAID 1+0
What is the sugget the performance setting?
Re: Airwave Performance Setting Adjusment
you shouldn't be using 7.2k HDs and raid 10 is recommended.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Moderator
Also, other factors that would be needed to help figure out how to better fine tune for performance:
1) number of monitored infrastructure devices (switches/controllers/APs)
2) client behavior (office [same clients everyday] vs hotspot/store [new unique clients daily])
3) amount of clients at peak hours
4) number of campus/buildings/floor plans in VisualRF
5) is there plan for network growth?
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Contributor I
1 controller
90 APs
office
about 100
2 buildings
HQ 12 floor
IT 14 floor
It was planned to be about 400 APs and 500 Clients on 2017.
Moderator
Sizing looks good for that type of deployment.  Like @pmonardo said, you should have at least 15k RPM disk drives or better since AirWave is disk I/O intensive.
Rob Gin
