Network Management
Airwave Report/Alert on Down radio
Looking to build either an alert or a report for APs when a radio goes down or BSSIDs go down. Had this happen a handful of times for unexplained reasons and looking to put something in place to notify us. Any ideas or options for how to accomplish this?
Thanks.
Michael Haring
If my answer is helpful, a Kudos is always appreciated!
Re: Airwave Report/Alert on Down radio
If you are pointing SNMP or Syslog at Airwave, you can use System> Triggers> Radio Down to produce an alert...
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
I think that will do the trick, thanks!
Michael Haring
