Network Management
Airwave Report - Identify Users Connected With Multiple Unique Devices
We're having an issue with staff logging into student devices for them to connect to the network. This creates a huge security risk for us as the staff is violating our terms of use, allowing students to bypass content filters, and we can no longer determine who was using the device. The last 2 are required by state law. I'm trying to create a custom report for Airwave to generate a report for: any account that is associated with more than 3 unique devices. Is this possible?  I'm not having any luck finding answers on here.
Re: Airwave Report - Identify Users Connected With Multiple Unique Devices
I just created a report using:
Client Session: Session Data by Client
Match Event: By Client
All Groups
All Folders
All Everything
I have extracted what I needed from the CSV with a pivot table and lots of manual work. I'm still looking for an easier way.
