Hi Community
I need to know, If I can to get a report of Top Applications Summary.
But without Bytes values consumed per application.
Best regards
Santiago
Currently i dont see a way to customize the report with only the Application name. However, you can always download the report in csv format and remove the column which shows the bytes consumed.
