Network Management
Airwave / Trigger / Connection attempt repeated an intruder on WPA2
  • 1.  Airwave / Trigger / Connection attempt repeated an intruder on WPA2
    Posted Mar 27, 2015 08:07 AM
    I would like to know how which parameter can we create a trigger for "too many login attempt repeated an intruder" on my WPA2/PSK
    Yann
  • 2.  RE: Airwave / Trigger / Connection attempt repeated an intruder on WPA2
    Posted Mar 27, 2015 01:39 PM
    You can try System -> Triggers -> add -> under RADIUS -> choose Client RADIUS Auth.  This allows you to have an alert if a client has X number of issues in a given period of time.
  • 3.  RE: Airwave / Trigger / Connection attempt repeated an intruder on WPA2
    Posted Mar 30, 2015 05:23 AM
    Hi Rob,
    Thanks for your answer but it's an SSID secure with wpa2 PSK, i think there no trace in radius server module ...
    Regards
    Yann
  • 4.  RE: Airwave / Trigger / Connection attempt repeated an intruder on WPA2
    Posted Mar 31, 2015 12:20 PM
    Doesn't seem like this is possible.  Most PSKs are based on internalDB entries that aren't visible outside the controller.  This is a good RFE to make on the controller side.
  • 5.  RE: Airwave / Trigger / Connection attempt repeated an intruder on WPA2
