Hello!
We have plans to set up triggers for a few things to try and catch issues early on.
The triggers we have tested the last few months have been:
CPU Utilization
Memory Utilization
Bandwith Utilization
The values that I´ve set as a test were:
CPU Utilization => 75% for 10min
Memory Utilization => 70% for 5min
Bandwith Utilization => 100 Mbit for 10 min (AP 105)
The reason I set these values was to evaluate if we could gain something usefull from them. For example if a device covered a to dense area and needed to be off-loaded by another AP, thereby providing a better user experience or if the AP for example had hung or were experiencing any other issues.
Now, here are my questions:
CPU Utilization => 75% for 10min seems to happen on a frequest basis. Is it recommended to set a higher value? Say everything under 85% is fine and results in no user experience degration?
Memory Utilization => 70% for 5min - Seems fine as it has never been activated and the working AP:s are genereally well below the threshold.
Bandwith Utilization => 100 Mbit for 10 min (AP-105). This could probobly be set to a higher value. But if we speculate that there will be max 20 clients connected to one AP, could the recommended value be set to, if any, for bandwith uthilization? I know there may not be a simple answer to this. Just wanna get some input on the values :)
Thanks!
/Mikael
