Network Management
Super Contributor I
Airwave Upgrade site - for a proxy
All,
I'm trying to figure out the URL that Airwave uses to query for new updates. I'm working with a customer and we're going to have to send Airwave through a proxy and restrict its outbound access to just this site.
Thanks for any help that you can offer!
-Mike
Re: Airwave Upgrade site - for a proxy
If you look in the amp-upgrade script, there should be some clues in there as well.  I can't remember the exact location of these scripts, but the linux commands find, locate and whereis will help.
Otherwise, try to do a pcap on airwave, then amp-upgrade.  You should be able to tell from the pcap what it is looking for in dns.
ACCP, ACCX #817, ACMP, ACMX #294
boston1630 wrote:
All,
-Mike
Instructions on how to upgrade Airwave through a Proxy:  https://arubanetworkskb.secure.force.com/pkb/articles/FAQ/How-do-I-upgrade-the-AMP-if-it-has-to-go-through-a-proxy-to-get-to-the-internet
You should be able to see the site in the Proxy afterwards.
Colin Joseph
Aruba Customer Engineering
Super Contributor I
All,
Thanks for the reply a month ago! It took me a hot minute to get back to this. I totally missed this in Colin's link - the site that the proxy was trying to hit was the support site at "support.arubanetworks.com." The "-x" flag on the end works as expected when a proxy allows the support site.
Thanks!
-Mike
