Network Management
Frequent Contributor II
Airwave Visual RF Planner suddenly is inaccessible and say try again ?
Suddnly I wasn't able to access Visual RF on airwave and say some thing like try again later and when I checkd the system tab Visual RF is disabled ? so how to enable it? as anything I clikc on RF planner tab is not working
Re: Airwave Visual RF Planner suddenly is inaccessible and say try again ?
Tim Cappalli | Aruba Security TME
when I click on Setup it gives the error thats why I cant do it
Dears I keep getting this erroras attached
Moderator
If you're not able to start up VisualRF from VisualRF Setup, then that means there's probably another issue happening in the background.  If the problem is persisting, I suggest opening a support case so that a TAC engineer can help diagnose the issue.
What AMP version are you currently running?  (you should be running at least 8.0.8.1)
Any errors in /var/log/visualrf/visualrf.log?
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
MVP
For some reason the VisualRF has halted. You should get some indication as to why under System -> Status -> VisualRF Engine (link to log file)
I've encountered this when there wasn't enough memory available for the VisualRF process to start. Verify the amount under VisualRF -> Setup. If at default it's 512, so try adjusting to 768 or 1024.
Regards
John Solberg
-ACMX #316 :: ACCP :: ACSA
Aruba Partner Ambassador
Intelecom Group - Norway
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
