Network Management
Frequent Contributor II
Airwave VisualRF 8 slow
I have a customer that just upgraded to Airwave 8 and the visualRF seems very slow and buggy. The slider will not release once clicked and the pages themselves seem to take forever to load. Is anyone else experiencing this or seen any reports of it?
Re: Airwave VisualRF 8 slow
Airwave 8.0.3 is scheduled to be released this week which should fix the VisualRF issues.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
ok, thanks!
AirWave 8.0.3 is now available.
http://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/EntryId/14758/Default.aspx
start_amp_upgrade -v 8.0.3
Tim Cappalli | Aruba Security
MVP
Did the 8.0.3 upgrade yesterday and the slowness appears to have been resolved.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
Interesting...
We were running 8.0.4.1 for a while and the system was very slow - VisualRF could not start always.
No we've upgraded to 8.0.5 and it seems better.
Regards
Martin
