Network Management
[Airwave] VisualRF Plan not accurate display
Hi everyone,
       I have a problem for Test Airwave VisualRF Plan but Display incorrect position.
Help me please!!
Re: [Airwave] VisualRF Plan not accurate display
Please search Airwave help for "Increasing Location Accuracy"
I suggest making sure the size of the floor plan is as accurate as possible but are you running 8.0.0 or 8.0.1? if you search on the forum for visualrf and airwave 8.0 you will find a post regarding a possible issue with the html5 version of visualrf.
if you switch back to the old flash based version is it more accurate?
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
MVP
Which device is really at that position? and what does the black circle represent?
We experienced some issues with accuracy on the heatmap, but the location seemed pretty good on 8.0.0.0 and upgradeing to 8.0.0.1 has helped.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
Just
Nirut wrote:
Hi everyone,
Help me please!!
Just looking at your diagram, I would say that you do not have enough density for an accurate fix.  You need AT LEAST 3 access points on the same channel as the client for a reasonable location calculation.  Assuming that all three of those are not on the same channel, you do not have that requirment.
I setup follow document " "Increasing Location Accuracy"".It not work.
Hi Evenone,
We try setup airwave follow parameter and debug.please see below.
Airwave info:
Version : 8.0.1
HTML5 : off
RTLS port : 5050
AP Channel provide :
Device Status.png ** I don't know. Why will be setup same channel?
log debug  :
I can receive log but not see detail
airbus_snoop rtls_tag_report : not display anything.
and When disable HTML5 VisualRF Plan display client see picture below.
if you want information please tell me.
Nirut Sattapan
Aruba Customer
You simply do not have enough access point density for location tracking.  Typically you need 3 access points on the same channel as the client to be able to triangulate the client.
Occasional Contributor I
We have the same problem as you describe.
As you can see, we have in this map 8 APs and visual RF is not working:
How could we fix this??
Thank you,
JMG
