Hi folks,
when i try to scale the floor plan i got the following error
have any one gote the same probleme as me ? and more important what can be the solution ?
We've had some issues with VisualRF and floor plans for some time, but all our problems were fixed after upgrading Airwave to version 8.2.0.3. Have you done that?
I have Version 8.2.0.3
What is the actual size of the floor plan? In VisualkRF we can load floor plans with max size of 2000X2000 feet. Any floor sizes above that will have issue in uploading them.
Regards
Gowri Amujuri
@gamujuri : i have upload a floorplan with less than 1312x1312 Feet.
@ rchahboune : That is strange. I have tested on my lab AMP servers and do not see the issue. Can we check on this on web meeting? Please send me the floor plan your uploading and AMP version to gowri.amujuri@hpe.com and we will work on the issue
