Network Management
Occasional Contributor I
Airwave and Aruba OS8
Wondering how would a current Managed mode airwave deployment function on top of Aruba OS 8 ?
Re: Airwave and Aruba OS8
The support in Airwave for AOS8 is monitor only. Effectively, the Mobility Master in 8 is capable of a wide variety of deployment scenarios with the new hierarchical configuration methodology.
In addition, in Airwave 8.2.5, we have added AirMatch dashboards!
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
If you found my post helpful, please give kudos
Wow I just upgraded my airwave and notice the air match function what a great feature
