Network Management
Contributor II
Airwave and Controller Rogue Detection
Hi All
I have a customer with a master local controller setup running AOS 6.4.2.4 on a pair of 7210's. We also have airwave configured and one of the main reasons for this was Rogue detection and alerting.
Currently, the controller can see one rogue on the security tab on dashboard. Airwave is also showing a rogue, which is great. Except, they aren't the same device.
Airwave says it learnt the rogue classification from a controller classification but the rogue Airwave knows about is not listed on the controller.
Even more strangely, even though the dashboard on the controller still shows one rogue, if I do 'show wms ap list' on the CLI, there are no rogues listed.
Airwave version is 8.0.6.3
Any help much appreciated
Re: Airwave and Controller Rogue Detection
Please read the airwave rogue classification chapter here:  http://www.arubanetworks.com/techdocs/AirWave_8_0_Web_Help/UserGuide.htm#AWUserGuide/Chapter6_RAPIDS/Using_RAPIDS_and_Rogue_Classification.htm#07rapids_1654598663_27976
Airwave has rules on top of what it learns from the controller about what to classify as a rogue, so you can expect more "rogues" from Airwave, just based on classification.  Rules can be relaxed or tightened based on what you consider a rogue.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Contributor II
Yes, I've read that before and I think I am doing the right thing with my rules but why does a rogue get reported as 'controller classified' when I don't have that AP listed on the controller? And why doesn't the AP that is classified as rogue on the controller, and meets one of my rules on Airwave, not appear on Airwave?
You should open a TAC case in parallel to make sure your rules are correct.  If the controller saw a Rogue AP, and the AP is removed, within 30 minutes it will no longer be on the controller.  Airwave will keep in historically much longer.
The AP that is classified as rogue on the controller, see if it is even in Airwave, but misclassified by one of your rules.
