Network Management
Valued Contributor I
Airwave and IAP-GUI-Config role rules (IP)
Hi All,
I'm currently deploying a customer's AMP-8.0.9.2, with IAPs on v6.4.2.6-4.1.1.10_51810.
We're also using the Instant-GUI-Config in the groups.
When configuring rules within a user role on the IAPs in this way, it doesn't seem to be possible to add a custom rule for anything other than TCP or UDP protocols. For example, I can't add IP protocol 51 for (ah).
Is there a way to do this?
Kudos appreciated, but I'm not hunting! (ACMX 104)
Re: Airwave and IAP-GUI-Config role rules (IP)
There are options to configure customer rules other than TCP and UDP.
CLI command is for protocol 51 (ah),
 rule any any match ah any any permit
GUI can be configured as below,
IAP-AH-1.JPG--
Rajaguru Vincent
Rajaguru Vincent
CWNA | CWSP | CWAP | CWDP | ACMP
Looking at those images you pasted, you're doing it directly in the IAP yes?
I tried that, and agree, it's possible in there.
When you try the same in the Instant-GUI within Airwave itself, that "other" option doesn't exist. Only TCP or UDP.
Any thoughts?
You are correct. I tried that directly from IAP. I checked on Airwave and couldn't find the OTHERS option in Airwave IGC. Please raise a TAC case.
Rajaguru Vincent
Rajaguru Vincent
Thanks for the confirmation. Thought that might be the situation.
Unfortunately I won't have time to log it with TAC (project timescales are tight on this one).
I'll just work-around it.
